-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   OBD P113C Code (http://forums.pelicanparts.com/mini-discussion-forum/776264-obd-p113c-code.html)
TC911e 10-13-2013 09:57 AM
OBD P113C Code
Has anyone else gotten a P113C code as a fault from the OBD readout? After the check engine light came on I had the code pulled a two different parts houses and both gave a P113C code with no other explanation. I haven't been able to find a cross reference with this code to find out what it's pointing to. It's not in the Bentley book (and even looks like the wrong format- 4 numbers vs. 3 numbers and a letter), and I haven't found anything on the web. The closest I've come is what appears to be an explanation on the iATN website, but it's a service for pros and you need to be a paid subscriber to read the response.
Does anyone know what P113C represents on a 2006 Mini Cooper S?
Luccia at Pelican Parts 10-02-2015 09:09 AM
(Late to the thread, but wanted to update for anyone else who has this error). It's been linked as an O2 sensor code. Are you using a generic code reader? I believe O2 codes range from P1132 - P1139 and the code you're getting is more of a generic reading with a non-specific BMW/MINI code reader.
