-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Clutch Master and Slave Cylinder Replacement (http://forums.pelicanparts.com/mini-discussion-forum/782521-question-clutch-master-slave-cylinder-replacement.html)
Ted (guest) 11-18-2013 06:06 PM
I have an '06 non-S and the slave cylinder looks nothing like the one in the pictures and is mounted into the transmission housing on the front of the car. Do you still need to compress the slave cylinder when bleeding? Thanks
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 11-18-2013 06:06 PM
Does is look like the one in the attached photo? You don't have to compress it, you can also pressure bleed the system which works quite well.
- Nick
http://www.pelicanparts.com/more_inf...30403-7144.jpg
tbearmini 11-18-2013 06:38 PM
Looks like same spot but the part looks like this number.
21-52-6-785-965-M33
http://www.pelicanparts.com/catalog/...785965-M33.jpg
