-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Jacking Up Your MINI (http://forums.pelicanparts.com/mini-discussion-forum/788405-question-jacking-up-your-mini.html)
fladale (guest) 12-22-2013 05:23 PM
I have a 2013 gp with a belly pan. The jack points are visible but not much else. There is a 2-3" wide section where the plastic was not installed, on a 45 degree angle that seems to have a frame rail seam sticking down 1/2" or so. Can this area be used to place a floor jack? I currently use it after inserting a piece of wood with a saw cut to allow at seam to not be used to lift the car.
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 12-22-2013 05:23 PM
I would suggest using the jack pints at the side. Not sure that brace is designed to hold the weight of the vehicle.
- Nick
