-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Automatic Transmission Fluid Change (http://forums.pelicanparts.com/mini-discussion-forum/788599-question-automatic-transmission-fluid-change.html)
Amish (guest) 12-24-2013 05:45 AM
I have a 2008 Cooper S that needs an auto transmission fluid change. The fill port seems to be in a different location than this article leading up to the 2007 model. Can you help me out in locating it?
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 12-24-2013 05:45 AM
There is a special tool required to get the fill plug out, MINI # 24 4 240. The fill plug is located at the back of the transmission, above the steering rack and sway bar.
- Nick
