-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Clutch Master and Slave Cylinder Replacement (http://forums.pelicanparts.com/mini-discussion-forum/797513-question-clutch-master-slave-cylinder-replacement.html)
Cmstackx (guest) 02-19-2014 11:59 AM
I have installed new clutch master and slave cylinders, I bought the Motive Power Bleeder and I'm still not getting the peddle I want. Is it possible to bleed the system with the slave cylinder attached? Also Can I compress the slaves piston in with it connected to the hydraulic line?
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 02-19-2014 11:59 AM
Yes, I have compressed slave cylinders before when they would not bleed. As pressure builds, it will become difficult to gold the slave compressed, allow it to push out onto the clutch fork.
- Nick
