-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Clutch Master and Slave Cylinder Replacement (http://forums.pelicanparts.com/mini-discussion-forum/797514-question-clutch-master-slave-cylinder-replacement.html)
Cmstackx (guest) 02-19-2014 12:00 PM
What I mean is, is it possible to bleed it using the peddle with the slave cylinder still attached? And if it can't be bled with it still attached, do I have to remove the hydraulic line before I can compress the piston in or can I leave the hydraulic line attached while I compress the piston in with my Steering wheel tool?
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 02-19-2014 12:00 PM
You can bleed the slave using the clutch pedal. As long as it is held all the way down, you can do it however you want.
- Nick
