-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Automatic Transmission Fluid Change (http://forums.pelicanparts.com/mini-discussion-forum/797519-question-automatic-transmission-fluid-change.html)
shrevemini (guest) 02-19-2014 01:07 PM
I did my transmission this weekend. I changed the filter. I started the fill process. At 2 quarts it started to come out the overflow. Is this right. I know im level. Any help would be great. John.
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 02-19-2014 01:07 PM
Sounds like not enough fluid to be full. Did you measure what came out of it? I find that helps when refilling, at least you can get the level close on the first try.
- Nick
