Your Hot Tip section suggests replacing the brushes first. Where can I get info on that procedure?
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
Remove the alternator, then remove the regulator from the alternator. There should be a few small bolts. First check if the regulator is available. Give our parts specialists a call at 1-888-280-7799. They can help you find the right part.
- Nick |
| All times are GMT -8. The time now is 06:27 PM. |
