-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Brake Pad Replacement (http://forums.pelicanparts.com/mini-discussion-forum/802420-question-brake-pad-replacement.html)
Carla (guest) 03-22-2014 06:28 AM
STUCK!
My dad is having issues pushing the cylinder back, is this normal? What is the best way to do it?
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 03-22-2014 06:28 AM
See Step9:
<strong>For the rear calipers on the MINI, retracting the pistons back into the caliper is a little different then the normal method. Most cars use a separate set of brake shoes on the inside of the rotor to act as the parking brake. On the MINI, it uses the brake pads themselves to clamp down on the rotor to lock the wheel. Due to the construction of this setup, the piston needs to be rotated at the same time it is pressed back into the caliper. BMW specifies the use of a special tool to do this, however, most auto parts stores sell a brake caliper retraction tool that fits into the holes on the brake piston as shown here.</strong>
- Nick
