-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Clutch Master and Slave Cylinder Replacement (http://forums.pelicanparts.com/mini-discussion-forum/810051-question-clutch-master-slave-cylinder-replacement.html)
Mr. FixIt (guest) 05-07-2014 09:37 AM
I replaced the slave cylinderfrom Pelican Partsand properly bled it. Now the clutch fork moves when the clutch pedal is pressed but the clutch does not disengage. I suspect my next move is inside the transmission. Seeking assurance before going further.
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 05-07-2014 09:37 AM
If the clutch hydraulic system is properly bled and still not disengaging, the clutch may be faulty.
- Nick
