2007 MINI Cooper not S. Changed rear brake pads, reset rear brake service on dash, now reads 37000 miles. However, the brake light on the dash that was red, now is still stays on but it is yellow.............any ideas?
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
Is it the same light that turns red with the parking brake engaged? This may be a fault in the ABS system. Was the light previously on?
I would start by checking the vehicle for fault codes. If multiple systems are not working properly, fault codes will be set. This will be your best bet when diagnosing. - Nick |
| All times are GMT -8. The time now is 08:06 AM. |
