-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Rear Shock and Spring Replacement (http://forums.pelicanparts.com/mini-discussion-forum/810056-question-rear-shock-spring-replacement.html)
Matt (guest) 05-07-2014 09:40 AM
the 13mm bolts aren't coming out, one has sheared off and the other wont budge, any suggestions on how to get the broken one out?
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 05-07-2014 09:40 AM
Remove the interior body panels, you may be able to access the top of the bolt. Spray it will penetrating oil. Then unscrew it upward using Vise Grips.
- Nick
