Hello thanks for sharing your info. I have a 06 mini cooper s . The passenger front bumper signal light/ fog light is out i replaced bulb , but it did not fix the problem , the old bulb was intact as well.
I noticed though that when i pressed the remote to unlock it flashed so i started t use turn signal and it works when using turn signal but off when headlights are on. No corrosion on socket . Please help. Thank you __________________ This post was auto-generated based upon a question asked on our tech article page here: |
The lights function from inputs to the body control module (BCM), all lights are directly controlled (activated) by the BCM. The inputs will have to be checked using a MINI scan tool. Otherwise you can check the grounds to the sockets and confirm there are not shorts.
- Nick |
| All times are GMT -8. The time now is 01:23 PM. |
