I could drive by,.....:
Do you recommend any antifreeze test strips in particular? Also not entirely clear how to jack vehicle up on mine at home when using the four point blocks. If I jack it 1st spot, high enough for jack stand, not going to come down level on same side adjacent block. Since have no rear differential, front wheel drive. Don't feel comfortable lifting so high angle for flat top jack stands. __________________ This post was auto-generated based upon a question asked on our tech article page here: |
Prestone makes decent test strips.
This article shows you how to jack a MINI: http://www.pelicanparts.com/techarticles/MINI/01-BASICS-Jacking_Up_Your_MINI/01-BASICS-Jacking_Up_Your_MINI.htm If you cannot get it on level ground or are uncomfortable, I would forgo attempting to jack the vehicle. - Nick |
