-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Window Regulator Replacement (http://forums.pelicanparts.com/mini-discussion-forum/818950-question-window-regulator-replacement.html)
Aloha808 (guest) 07-02-2014 10:30 AM
Posting here cause it was the closest in proximity to the issue at hand. Is there a way to unlock the door through the door panel oval via wire?? My passenger door is locked fr inside and outside. Door panel barely pried open. Considering removing the seats. Any help is much appreciated! Other forums are no help on this.
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 07-02-2014 10:30 AM
Yes. With the door panel removed, follow the door lock rod down to the latch. Then move the lever the rod connects to to unlock.
- Nick
