-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Automatic Transmission Fluid Change (http://forums.pelicanparts.com/mini-discussion-forum/820449-question-automatic-transmission-fluid-change.html)
Mike (guest) 07-13-2014 05:35 AM
Hi Nick, Is there an aftermarket transmission oil cooler adapter available? I am thinking on something similar to the engine oil cooler adapter photo attached? Also, in other manufacturers vehicles the torque converter usually has oil in it that will not drain out from the transmission oil drain plug. How can the torque converter oil be drained? I would be happy to elaborate on both questions if they are not clear. Happy Independence Day, Mike
http://www.pelicanparts.com/more_inf...87309-6348.jpg
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 07-13-2014 05:35 AM
I am sure there is an aftermarket cooler you can use. There are many universal options use for towing, etc.
A lot of modern converters have no drain. So you are draining what will come and filling it back up. Replacing maybe 2/3s of the fluid. To replace all of the fluid, you would need a flush machine, to pump out the old while pumping in the new at the same rate.
- Nick
