coolant level is OK,let it idle till the temperature came up the fan never came on.I have check all the fuses,how can I check the fan to see if it needs replacement.
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
Check for power and ground to the fan when it is commanded on. If power and ground are present and the fan does not run, it is faulty.
- Nick |
| All times are GMT -8. The time now is 08:43 PM. |
