-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Brake Pad Replacement (http://forums.pelicanparts.com/mini-discussion-forum/824448-question-brake-pad-replacement.html)
Spagtio (guest) 08-08-2014 05:58 AM
Yes nick, the pedal is stiff with the engine running.
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 08-08-2014 05:58 AM
Confirm the brake booster is getting sufficient vacuum. If so, the calipers may be jammed from the pads. Double check the part numbers you installed. If too big, they may prevent the piston from moving.
- Nick
