Would a weak master or slave cylinder give a short throw to the clutch arm? I only get about 14.5mm of throw at the end of the arm. Is that enough to disengage the clutch completely? Shifting is notchy and clutch engages close to floor.
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
Yes, if the slave or master cannot hold the pressure needed to relieve the pressure plate, the clutch will not disengage.
- Nick |
| All times are GMT -8. The time now is 02:08 AM. |
