-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Window Regulator Replacement (http://forums.pelicanparts.com/mini-discussion-forum/826514-question-window-regulator-replacement.html)
eWhizz (guest) 08-22-2014 06:36 AM
My window can be pushed up and down by hand. The motor can be heard running when you use the switch. The motor operates in both directions, just the window doesn't move with the motor.
Should I be replacing the gearbox or regular or could something just worked its way loose? Or has the drive on the motor broken?
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 08-22-2014 06:36 AM
I would start with replacing the regulator.
- Nick
