-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Coolant Change (http://forums.pelicanparts.com/mini-discussion-forum/833231-question-coolant-change.html)
Buzzard (guest) 10-08-2014 12:49 PM
Replaced 3 radiator hoses and followed your process to refill, but now have leak from driver's side of engine. Removed battery box for visibility, attached a pressure tester & pumped up to rated psi. Can't see anything leaking, or even dripping under car, but pressure gauge bleeds down in ~ 10 seconds. Any ideas?
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 10-08-2014 12:49 PM
Grab a mirror and inspect the area. There may be a seal or gasket leaking. Check if the cooling blocking plate or elbow for coolant pump on the crankcase are leaking.
- Nick
