-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Thermostat Replacement (http://forums.pelicanparts.com/mini-discussion-forum/833469-question-thermostat-replacement.html)
Brandon (guest) 10-10-2014 09:18 AM
My 2002 MCS is overheating, not really sure why but i'm guessing it is the thermostat. Took it to the dealer, said the head gasket was broken, i turned on my car the day before and it did not show any signs of a broken head gasket. There is coolant in the reservoir and no leaks anywhere. any suggestions??
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 10-10-2014 09:18 AM
I would pressure test the cooling system. If the system will not hold pressure and there are no external leaks the head gasket may be faulty.
- Nick
