-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Manual Transmission Oil Change (http://forums.pelicanparts.com/mini-discussion-forum/834906-question-manual-transmission-oil-change.html)
MS (guest) 10-20-2014 10:16 AM
I have mini cooper 2008 automatic convertible , i have no problems in changing gears or when i stop but when i press the pedal the RPM is increasing but the acceleration is not as much as the fuel increase , is this a transmission problem or wht it could be
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 10-20-2014 10:16 AM
First check the transmission fluid level to be sure it is correct. Then check the transmission ECM for fault codes. If the system is not working properly, a fault code will be set. This will be your best bet when diagnosing.
- Nick
