Guest
Posts: n/a
I have mini cooper 2008 automatic convertible , i have no problems in changing gears or when i stop but when i press the pedal the RPM is increasing but the acceleration is not as much as the fuel increase , is this a transmission problem or wht it could be
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
First check the transmission fluid level to be sure it is correct. Then check the transmission ECM for fault codes. If the system is not working properly, a fault code will be set. This will be your best bet when diagnosing.
- Nick |
