-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Clutch Master and Slave Cylinder Replacement (http://forums.pelicanparts.com/mini-discussion-forum/835517-question-clutch-master-slave-cylinder-replacement.html)
Jay (guest) 10-24-2014 05:22 AM
Just some clarification. The car shifts and drives fine. You wouldn't know there was issue until I step on the clutch pedal. That's the only time you hear the loud screeching noise. I'm thinking bad throw out bearing. Any thoughts? Thanks.
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 10-24-2014 05:22 AM
Noise only there when you step on the clutch, likely the throwout bearing.
- Nick
