-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Shift Cable Replacement (http://forums.pelicanparts.com/mini-discussion-forum/836812-question-shift-cable-replacement.html)
martin (guest) 11-02-2014 07:25 AM
Hi
My daughter has just purchased a 2002 mini 1 1.6 and the gear shift is very stiff although it does select gears. 1st and 5th are pretty bad. Is this a cable issue
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 11-02-2014 07:25 AM
COuld be. Detach the cables from the trans. If shifting is easy, replace the cables.
- Nick
