-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Clutch Master and Slave Cylinder Replacement (http://forums.pelicanparts.com/mini-discussion-forum/837655-question-clutch-master-slave-cylinder-replacement.html)
Yann (guest) 11-07-2014 05:31 PM
Just had a new clutch fitted on my 54 plate mcs convertible and now the pedal is firm initially then soft. It engages at the top of the pedal travel where the spring is strongest making it very hard to pull away smoothly. I tend to wheel spin or stall. The garage reckoned they did not need to bleed the assembly when fittin the clutch. Any ideas to smoothen out the pedal travel?
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 11-07-2014 05:31 PM
I would try to bleed the system, it does sound like air is trapped.
- Nick
