Changed to Valero clutch kit, replaced with used transmission and added new slave & master. Slave doesn't push arm enough to be able to change gears... bled it multiple times. Any ideas?
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
Double check the part number of the clutch you installed. It may be wrong. Also check if it looks like the slave is not extending far enough, You may have a faulty master or slave cylinder.
- Nick |
