-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Thermostat Replacement (http://forums.pelicanparts.com/mini-discussion-forum/839529-question-thermostat-replacement.html)
Reg (guest) 11-20-2014 12:49 PM
Hi. I have a 2003 MINI Cooper not an "S". I had the radiator replaced, and after getting it back from the shop, I noticed that the radiator itself has some "play" in the mounting. Is this normal?...Should the radiator be solidly mounted, so there is no play or movement? Please HELP!
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 11-20-2014 12:49 PM
It is mounted in rubber grommets, so a small amount of movement is OK.
- Nick
