-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Thermostat Replacement (http://forums.pelicanparts.com/mini-discussion-forum/839532-question-thermostat-replacement.html)
Reg (guest) 11-20-2014 11:58 AM
Thanks for the info Nick. But the radiator movement seems to be around the two mounting pins at the top right/left of the radiator. Movement of the radiator is about 1/2 inch or so along those two pins. Is that normal?
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 11-20-2014 11:58 AM
Not likely, the retaining pins should hold it pretty well. 1/2 inch each direction is too much.
- Nick
