-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Window Regulator Replacement (http://forums.pelicanparts.com/mini-discussion-forum/843383-question-window-regulator-replacement.html)
mongoman7071 (guest) 12-19-2014 04:07 PM
update: By powering up and placing the LHS window switch -Down, the motor worm screw ....unscrewed itself from the Regulator. Ok motor obviously works . The big problem still exists, how to get the window to come down with a regulator that is probably Jammed. Any Ideas would be appreciated.
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 12-19-2014 04:07 PM
If the regulator is faulty, cutting the cable will release it.
- Nick
