-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Clutch Replacement (http://forums.pelicanparts.com/mini-discussion-forum/847061-question-clutch-replacement.html)
Phil D (guest) 01-16-2015 01:10 PM
Actually, I have not been able to remove the throw out fork. Here is another picture which shows the welded part more clearly. My guess this is a modification the previous owner made. Other than cutting the throw out fork shaft, I cannot think of another way to remove it.
http://www.pelicanparts.com/more_inf...29539-2972.jpg
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 01-16-2015 01:10 PM
Ok I see it better now.
On the far side away from the lever, on the right of the image. There is a pin that release the shaft. Then slide it out and remove it along with the bushings. I would replace the shaft. bushings and pin.
- Nick
