-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Manual Transmission Oil Change (http://forums.pelicanparts.com/mini-discussion-forum/849067-question-manual-transmission-oil-change.html)
KirbyGo (guest) 01-28-2015 04:08 AM
i changed my transmission fluid today on my R53 2005 mini cooper S and there seems to be a leak. I tightened the fill and drain plug to 32 ft lbs just like the article says. Should i tighten them even more? or will that cause the plugs to fail like mentioned in a previous comment?
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 01-28-2015 04:08 AM
Do not over-tighten the plug. Try replacing it is the leak is from there.
- Nick
