-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Mini power steering fluid leak (http://forums.pelicanparts.com/mini-discussion-forum/852096-mini-power-steering-fluid-leak.html)
ptkacik 02-17-2015 06:51 AM
Does Pelican Parts sell the proper hose clamps for the R50 power steering reservoir hoses?
My 2005 Mini R50 is leaking fluid from the top of the hose at the power steering reservoir. I replaced the Clic Clamp hose clamps with a worm screw type but the leak is only worse. I keep the CHF-11 fluid topped up.
I now understand that the Clic and Clic-R Clamps are not only quicker to install in the factory, but also clamp better and have an effective tension spring to maintain tension in cold weather. I am also wrestling with this clamp issue on my E320 Mercedes fuel lines.
Please help,
Peter
