-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Clutch Master and Slave Cylinder Replacement (http://forums.pelicanparts.com/mini-discussion-forum/852136-question-clutch-master-slave-cylinder-replacement.html)
eggsalad (guest) 02-17-2015 10:59 AM
So I replaced the slave and master clutch cylinders on my '12 countryman S All4. After bleeding, the clutch pedal feels very stiff, and when the engine is running and I press the clutch pedal there is a loud, metalic, "tang tang tang tang..." sound coming from the clutch area. I am out of ideas. Thoughts??
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 02-17-2015 10:59 AM
The clutch fork may not be properly installed, or the throw-out bearing.
- Nick
