Guest
Posts: n/a
After I bleed the slave cylinder it doesn't want to hold the pressure I put on it from the clutch pedal, the second I press it it shoots out the tube connected to the slave cylinder, made sure I put the rubber nipple back on and everything...
![]() __________________ This post was auto-generated based upon a question asked on our tech article page here: |
The line shoots out? The slave or line may be damaged. Inpspect the line groove where the clip sits.
- Nick |
