-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Shift Cable Replacement (http://forums.pelicanparts.com/mini-discussion-forum/852551-question-shift-cable-replacement.html)
Muji (guest) 02-20-2015 04:41 AM
I own a 2004 Cooper S and I'm having a tough time getting into gear when the car has been in the summer sun the whole day. By tough, I mean I really need to force the shift stick to go into gear even when the clutch is in all the way down. If I were to then drive the car a ways without shifting, it gets better.
In the winter, I usually don't have this issue except when I have been constantly shifting for some time.
What could be wrong? Thank you very much
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 02-20-2015 04:41 AM
Sounds like failing shift cables.
Give our parts specialists a call at 1-888-280-7799 and they can help figure out which part or repair kit you need.
- Nick
Dave at Pelican Parts 02-20-2015 07:20 AM
Another area to inspect would be the clutch. Try bleeding the clutch if you can.
--DD
