-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Clutch Replacement (http://forums.pelicanparts.com/mini-discussion-forum/854829-question-clutch-replacement.html)
Dee (guest) 03-06-2015 02:22 PM
Just replaced my MCS clutch with a Valeo SMF kit. Before putting the radiator back etc. I turned on the car and noticed the passenger side axle isn't moving while in gear. Drivers side axle is out of the car waiting on a new one. I can see a bit of motion in the diff and it's sporadic. My car has a LSD. Is what I'm seeing related to that? It's worth mentioning I replaced the slave cylinder and it might not be properly bled. Do you think the transmission will actually rotate the axle once the tires are on and the car is on ground? I'm pretty sure I installed the clutch right and I don't hear any bad noises while the car is running.
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 03-06-2015 02:22 PM
You're trying to drive one axle without the other installed? Wait until you have both axles installed before chasing things like this.
- Nick
