Can the pre 12/2003 upper motor mount be replaced by the post 12/03 style. By removing the extra motor mount bracket, are the correct bolts holes in place for the 16mm bolt that goes in the frame for the newer style mount
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
I do not know. I would think the long block is the same, with the same holes. But i can't be sure.
I opened a post in our forums. A Pelican community member may be able to answer your question. - Nick |
