-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Power Steering Pump Replacement (http://forums.pelicanparts.com/mini-discussion-forum/857469-question-power-steering-pump-replacement.html)
mivageze (guest) 03-24-2015 06:47 AM
Hello Nick.can you help me with a problem…
i own a R50 minicooper,2004.after having the alternator repaired,the steering wheel has become very stiff and difficult to turn.is this a question of the power-steering system or something else.Do i need to have the power-steering serviced.live in Bosnia and Herzagovine and wish to know if the global service is ok.the car has 148,000klm on the clock.thank you for your help.
http://www.pelicanparts.com/more_inf...52892-6436.jpg
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 03-24-2015 06:47 AM
I would check if the power steering pump is turning on. If not, check power and ground to the pump, if present, the pump could be faulty.
- Nick
