-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Help with codes from trip computer menu? (http://forums.pelicanparts.com/mini-discussion-forum/859377-help-codes-trip-computer-menu.html)
INFJ 04-05-2015 10:17 PM
I am getting the following 3 ERROR codes from the trip computer menu 14:
ERR01 9319h
20004ECA7800
ERR02 931Ah
20004ECA7800
ERR03 9314h
202851407A00
The nearest dealer is about 2.5 hours each way from me, does any one have an idea about the meanings of these codes.
2010 Mini Cooper S with just over 103k, recently had plugs and filters (air, cabin, & fuel) changed along with Belt (A/C, Alternator, Water Pump belt).
The water temperature and engine light came on about 2 miles from home.
The oil color appears normal, the lower radiator hose is loosened and has a soft spot (I know this hose needs replacing), but what are the codes pointing to.
bluefox280 04-07-2015 10:14 AM
Can you pull any codes with a OBDII serial port reader?
Those trip computer codes, unless you have a factory service manual, aren't going to give you anything to even give a slim picture of what's going on.
- Erik
INFJ 04-07-2015 08:13 PM
I do not have a serial port reader of any type.
I was just hoping someone might have access to some TIS info about these codes.
It's a long shot but I'll probably call MINI service.
