-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Installing A High Performance Coil Pack (http://forums.pelicanparts.com/mini-discussion-forum/860567-question-installing-high-performance-coil-pack.html)
Gary (guest) 04-14-2015 07:05 AM
Hi just had leak blow through coolant reservoir saturating coil
unfortunate placement of both car not turning over
I'm assuming coil is damaged what say yee?
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 04-14-2015 07:05 AM
I would think so, or just soaked and causing arcing. Try drying it off, then check spark output. Should be able to produce 20kv.
- Nick
