-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Front Shock and Spring Replacement (http://forums.pelicanparts.com/mini-discussion-forum/863312-question-front-shock-spring-replacement.html)
Seth (guest) 05-01-2015 06:17 AM
Just replaced mine and just FYI, you really don't need to remove the tie rod ends. It's just an extra unnecessary step. I just lowered it down with a jack and gave it a shake and the shock popped on out.
Also if you don't have a socket wrench with the through socket type, a 17mm wrench fits over a flat area around half way down the bolt for the sway bar links which allows you to easily loosen and tighten the bolt.
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 05-01-2015 06:17 AM
Thanks for the additional info and feedback. We appreciate it.
- Nick
