-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Manual Transmission Oil Change (http://forums.pelicanparts.com/mini-discussion-forum/864938-question-manual-transmission-oil-change.html)
Largo (guest) 05-12-2015 05:30 AM
What transmission fluid plug do I buy for a 2009 MINI Cooper with a 6-speed manual? How do I remove the plug? It's a flat cap that says "DO NOT remove, "lifetime" fluid."
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 05-12-2015 05:30 AM
Can you share a photo of the cap? See this tech article:
http://www.pelicanparts.com/techarticles/MINI_R56/01-TRANS-Manual_Trans_Fluid_Replacing/01-TRANS-Manual_Trans_Fluid_Replacing.htm
Give our parts specialists a call at 1-888-280-7799. They can figure out what part or repair kit you need.
- Nick
