-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Shift Cable Replacement (http://forums.pelicanparts.com/mini-discussion-forum/870403-question-shift-cable-replacement.html)
Flo (guest) 06-12-2015 11:35 AM
Hi! I have a 2002 Mini with manual transmission. I stopped at a trafic light and the gear was stuck in 5th. I tried to force it to neutral but nothing... what can it be? I now see that there was a recall regarding shift cable detachment, can that be the problem? Can it be re attached? Thanks!
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 06-12-2015 11:35 AM
I would check the shifter cables. They have been troublesome in the past. Check to see if they are attached properly or binding.
- Nick
