Thanks for the instructions, but this part is confusing me: "You'll want to fill the engine until you start to see coolant coming out of both vent screws. Once you see this, close both of the screws. Keep filling the reservoir until it no longer drain into the filler neck. Now remove the reservoir and close the vent screws."
It says to close the screws and then it says to do other stuff and close them again. __________________ This post was auto-generated based upon a question asked on our tech article page here: |
Fill until coolant flows out of the vents, then close them. They now remain closed.
I will have the article updated, to remove the confusion. Thanks for catching that. - Nick |
| All times are GMT -8. The time now is 11:50 AM. |
