-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Window Regulator Replacement (http://forums.pelicanparts.com/mini-discussion-forum/875176-question-window-regulator-replacement.html)
Mike (guest) 07-17-2015 09:54 AM
These are great instruction with one missed note. On both of my replacement window motors, they ran backwards. It's a simple correction, but extremely frustrating if you're already at step 40 when you figure it out.
The fix is to remove the 4 screws holding the motor casing in place, lift about 6mm and then rotate 180 degrees. Press back down and re-install screws refer to attached picture.
I suggest testing the motor in the harness before installing on the window regulator to save the head ache. Easy fix and much less frustrating than finding out after install.
http://www.pelicanparts.com/more_inf...05983-5140.jpg
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 07-17-2015 09:54 AM
Thanks for the additional info. We appreciate it.
- Nick
