-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Window Regulator Replacement (http://forums.pelicanparts.com/mini-discussion-forum/875177-question-window-regulator-replacement.html)
fillipos (guest) 07-17-2015 09:54 AM
Hi All at Pelican, i have just read this and it looks very useful.
The problem i have is the window does not drop that small amount when you open the door and seems jammed is this a symptom of the mech needing replacement
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 07-17-2015 09:54 AM
What kid of vehicle?
- Nick
Dave at Pelican Parts 07-17-2015 02:34 PM
Will it open at all? If so, it may simply have lost where it thinks the open and closed positions are. You can re-initialize the window by doing the following:
- Roll the window all the way down. Keep the switch down for another 5 seconds after it is open.
- Roll the window all the way up. Keep the switch up for another 5 seconds after it is closed.
That should re-set the open and closed positions stored by the car.
--DD
