-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Automatic Transmission Fluid Change (http://forums.pelicanparts.com/mini-discussion-forum/879845-question-automatic-transmission-fluid-change.html)
Gary (guest) 08-21-2015 05:17 AM
Sorry for the explanation. The car moves forward normally in first but seems to rev higher then it should before switching to second gear. If I switch to paddle shift the gear changes are immediate. I was told at the dealer that the CVT transmission has no filter...is this true?
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 08-21-2015 05:17 AM
That is correct, no filter.
You may need an adaptation. I would grab a repair manual with the procedure, it has to be done exactly right. Give our parts specialists a call: 1-888-280-7799
- Nick
