Replacing rear brakes and rotors no problem. Went to replace the sensor. Found the sensor too short. Wont fit from brake to connector Store says its the correct one. I have a 2009 the sensor length is 44 incnes long end of connector to sensor.
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
I don't have anything to check the length against.
I’m not the best with part numbers. Give our parts specialists a call at 1-888-280-7799. They can figure out what part or repair kit you need. - Nick |
44 inches total length sounds about right, at least for my 2012 model. Are you sure you're routing it correctly?
--DD |
| All times are GMT -8. The time now is 06:39 PM. |
